| Home > Help Needed / General Tech Chat > Fuel Pump Question | |||||||
64 Posts Member #: 10995 Advanced Member North Yorkshire |
28th Mar, 2015 at 05:29:16pm
I am looking at using an injection Mini fuel tank for my next turbo conversion and I guess the pump will not be up to the job. What have the brainy people used? Class D Winner 1997 - 1998 - 2003
28th Mar, 2015 at 05:46:55pm
I ran one for a wile fine I have started posting on Instagram also my name on there is turbomk1golf
28th Mar, 2015 at 06:33:13pm
Spi will be ok for up to 10psi or so. Mpi for anything above that. On 11th Feb, 2015 robert said:
29th Mar, 2015 at 02:55:32pm
Mpi pump/tank is perfect. The tanks are a matt gray finish and sound "dull" when you tap them. Best bet is to look up the mpi pump part # and make sure it's the right one... On 17th Nov, 2014 Tom Fenton said:
29th Mar, 2015 at 02:56:42pm
Oh, and get the tank strap to match the mpi tank, or be prepared to shorten the stock one. On 17th Nov, 2014 Tom Fenton said:
29th Mar, 2015 at 03:35:27pm
Mpi tank has a short filler neck and sound deadening on the outside. On 11th Feb, 2015 robert said:
![]() 1751 Posts Member #: 10190 Post Whore belgium |
29th Mar, 2015 at 04:38:25pm
Can a mpi pump be fitted to a spi tank? Heard it was the same. you can do anything if you set your mind to it...
29th Mar, 2015 at 04:44:20pm
29th Mar, 2015 at 06:52:54pm
Thank heaven for that as I have an SPI tank on the shelf. Class D Winner 1997 - 1998 - 2003
976 Posts Member #: 3228 Post Whore North of the Netherlands |
30th Mar, 2015 at 12:04:14pm
Iirc someone on here has put a Honda pump in one and that was easy to do.. (?) Dazed and Confused.... |
