Home > Help Needed / General Tech Chat > Oil Filter Relocation
Curtis Brown
Member #: 10048
I am wanting to install an oil filter between the gearbox and the oil pump, but I cannot find much information on the subject. Please post any photos or details you may have on the topic. Thanks
time for some TM photoshop..
Chalkie
Member #: 9764
Northamptonshire.
isn't this how its done anyways? gear box - pick up pipe - oil filter - pressure valve - oil pump - oil ways - gearbox?
Curtis Brown
Member #: 10048
No, the oil pump is fed with unfiltered oil.
slater
Member #: 1291
Suffolk / Birmingham
Could be wrong but i dont think the pump would have enough suction to pull oil though a filter. You could possibly try by taking a pick up via the sump plug and putting it back in where the pickup pipe normally attaches.
graemec
Member #: 1424
Carnforth, Lancs
Time for some TM searching
slater
Member #: 1291
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=179419
It can be done and I have seen it done with filter between box and before the pump. Bit of a ball ache to prime the system though.
Curtis Brown
Member #: 10048
Would filter location affect that?
