| Home > Help Needed / General Tech Chat > n/a afr readings? | |||||||
3rd Apr, 2015 at 11:59:31am
Hi
My build thread..
3rd Apr, 2015 at 12:01:24pm
Should of said. It's a naturally asperated 1380 with 11.2:1 cr.
My build thread..
3rd Apr, 2015 at 12:04:58pm
Sounds pretty ideal to me.
3rd Apr, 2015 at 03:19:00pm
If it's running nice and feels good under foot, responsive etc I wouldnt worry too much.
3rd Apr, 2015 at 03:20:06pm
Yea I had no doubt in the setting up as he's very well respected. Just wondered if the gauge was telling porkys lol.
My build thread..
3rd Apr, 2015 at 04:34:41pm
As the gents state above JT, your rolling road guru got this spot on.
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
4th Apr, 2015 at 06:27:51pm
I've got an AFR meter in my n/a mini too. In case of cruise / part throttle the AFR is above 15,5, I always experienced this was a matter of misfire. When one cilinder is not working under that condition, the unburnt (thus plenty oxygene in exhaust) mixture causes high numbers at the AFR meter.
4th Apr, 2015 at 06:58:39pm
be carefull with 'diagnosing' misfires based on AFR, its not quite as simple as black and white
Yes i moved to the darkside |
4th Apr, 2015 at 07:05:24pm
Any non fire event will show a leaner reading. But too lean can cause a misfire...which in turn can show even leaner.
5th Apr, 2015 at 06:57:06am
The castrol additive uses phosphorous to replace the lead.
Edited by Rod S on 5th Apr, 2015. Schrödinger's cat - so which one am I ??? |
5th Apr, 2015 at 09:27:23am
We seem to be having a problem with wideband accuracy, when taken to southam the wideband readings were literally miles off what their own afr readings were. The controller is an innovate LC-2 and I've tried recalibrating the sensor to no avail, it's probably been installed for around 6-8months. The lead replacement additive for the 12g295 is added to the tank, we've used various types, millers, carlube, redline and have used most recently redex lead replacement stuff picked up at shell. Is there a way of fixing the miles off wideband readings short of a new sensor? And peoples opinions of the least damaging additive? On 26th Jan, 2012 Tom Fenton said:
5th Apr, 2015 at 10:06:58am
What is southam and what wideband or AFR monitoring setup do they use ?
5th Apr, 2015 at 11:02:14am
Sotham mini and metro centre, i couldn't tell you what machine they use for using the rolling road there On 26th Jan, 2012 Tom Fenton said:
5th Apr, 2015 at 11:45:54am
On 5th Apr, 2015 Carlzilla said:
And peoples opinions of the least damaging additive? Possibly anything other than the phosphor based ones. But there doesn't seem to be any research (well not obvious) on it but sodium and manganese are completely the opposite side of the periodic table to phosphor and lead. Anyone remember the news from about 4-5 years ago when several of the supermarkets, Tescos particularly, had to pay out millions for repairs to modern cars - which all had failed wideband sensors plus other follow-on damage and the root cause was traced to their bulk fuel supplier who had decided to swap a couple of very large storage tanks from diesel to unleaded. They didn't flush the tanks out and diesel contains a lot of silicone (to lubricate modern diesel injectors) and Bosch list silicone as the other big killer of widebands. Schrödinger's cat - so which one am I ??? |
5th Apr, 2015 at 12:02:23pm
I never did understand why people keep calibrating a used sensor. It makes no sense. The sensor is dirty.
5th Apr, 2015 at 12:36:35pm
OK, this is going slightly O/T (don't these threads always) but I couldn't agree more.
5th Apr, 2015 at 12:37:56pm
So really there's not a lot of point of having one on a carbed mini that uses leaded substitute?
My build thread..
5th Apr, 2015 at 12:58:03pm
On 5th Apr, 2015 JT said:
So really there's not a lot of point of having one on a carbed mini that uses leaded substitute? That's not necessarily true. Bosch just say phosphor kills them (along with silicone). So first, swap to one of the substitutes that doesn't use phosphor. Search any of the classic or historic car websites to see which metal each of the substitutes uses instead of lead. One of them may even recommend which is best for a wideband sensor, all I know from previous research is avoid phosphor. (my previous research was actually based on the ZDDP in engine oil, not what you add to the fuel, I don't add anything as I have an unleaded head) Schrödinger's cat - so which one am I ??? |
5th Apr, 2015 at 01:58:55pm
I'll have a look.
My build thread..
5th Apr, 2015 at 02:36:50pm
Valvemaster is phosphor based, so upon that it's not much good for a wideband, millers seemed okay, can't find any info on redex On 26th Jan, 2012 Tom Fenton said:
5th Apr, 2015 at 02:42:52pm
I doubt your readings are way out yet due to the castrol additive, it's a bit too soon.
5th Apr, 2015 at 03:43:42pm
If I understand correctly, a contaminated sensor just gets sluggish to respond. Any drift in the AFR would mean something else?
109 Posts Member #: 10368 Advanced Member Australia |
5th Apr, 2015 at 11:00:31pm
I have a couple of innovate wideband sensors, and i think they are bosch. As Rod S says the positioning of the AFR plug makes a difference particularly at idle. ( more of that plain air getting around the place). Also check the readings trend on long periods of WOT.. as dynos sometimes don't do prolonged pulls.... i found a leaning off after about 20seconds... that i wouldn't have guessed at nor necessarily found otherwise |
