Home > Help Needed / General Tech Chat > Auto sparky wanted in bham
robj
Member #: 11059
Ok got a few issues I need sorting before mot in couple of weeks time being colourblind badly lol I won't even change a plug anyone more than competent or know of someone who is? I have a 71 clubman with no indicators and rear light issues but also want a general check over all the wiring.
Cheers bob
PhilR
Member #: 10034
Birmingham
Where in Birmingham are you?
robj
Member #: 11059
Castle bromwich
robj
Member #: 11059
anyone available?
I will obviously pay for there time
PhilR
Member #: 10034
Birmingham
Maybe worth elaborating on the problems, and stating what you've checked so far.
People may have some easy things for you to check before you get anyone out.
robj
Member #: 11059
ok fair enough well I have headlights which work on high and low beam and flash fine
I have no indicators but 1 sidelight does work there isn't any clicking noises just nothing
no brake lights
but have rear lights but passenger is dim compared to the other side
I have changed the fuses and the indicator relay and changed all bulbs to new
the fuse box is the original on drivers inner wing 2 fuse set up and the wiring hasn't been altered in anyway
Earths, indicator flasher unit, dodgy wire for the brakelights, probably on the bulkhead top right where the loom joins, or possibly brake light switch, or a connection has come off it
