Home > Help Needed / General Tech Chat > Turbo question
Moggyton
Member #: 11086
Staffordshire
Hi, i have a gt17 turbo and a mirage manifold. The gt17 is water and oil cooled and it wont really fit without any mods to the bulkhead. Is there a smaller turbo or version of the gt17 that should fit?
JT
Member #: 637
Hertfordshire
Look up gt15
My build thread..
Moggyton
Member #: 11086
Staffordshire
I want something just as efficient, if anyone has anything?
Callum
Member #: 10396
Stoke-on-Trent
I would be interested in the gt17 and manifold if you decide to sell
Gt17 does fit without bulkhead mods. You must have the wrong manifold.
Moggyton
Member #: 11086
Staffordshire
Its a manifold from Matty off here.
It was designed to fit without bulkhead mods...
Moggyton
Member #: 11086
Staffordshire
Well thats great to know, but it doesnt. Lol
jonny f
Member #: 9894
Dorking
what engine steady are you using?
Very late subframe has the engine further back to.
Tuctuc
Member #: 10894
Lancashire
I have this and it fits.
As suggested what engine steady are you using, an adjustable would allow you to angle engine slightly plus what subframe. I've a late subframe and engine mounts are approx 10mm further forward.
As an afterthought, you have got the std Matty manifold and not the performance one with longer tracts?
Pictures!!
Moggyton
Member #: 11086
Staffordshire
Not 100% sure. Are their different size bodies for the gt17?
fixitphil2
Member #: 10945
scarborough/ northyorkshire
i have just finished doing my turbo conversion with matty manifold and a gt1752 turbo.you have turn the compresser housing and cut off the actuator mount and weld it in a diffrent position.you will need to grind a small bit of the block too.i had to get a ajustable engine steady and lengthen it some more
Edited by fixitphil2 on 24th Apr, 2015.
