Home > Help Needed / General Tech Chat > safe boost pressure
wolfie29177
Member #: 476
The Black Countraaaaay
I've managed to get the compression ratio on my engine down to 8.1 and have uprated the diff so wondering just how far I can push the boost before I risk destroying the engine?
Masturbation is not a crime its a hobby
What Turbo ? Intercooler, what ignition ? What pistons ?
A little more detail will help.
Phil.
wolfie29177
Member #: 476
Standard turbo pistons and turbo but Avonbar adjustable wastegate actuator. Ignition is megajolt and I've got an alloy R5 intercooler. The diff is a minispares 4 pin. Head is fully ported with chambers enlarged
20psi+ has been done
Edited by Brett on 26th Apr, 2015.
Intercooler will blow apart long before the engine will be troubled as long as it's tuned correctly.
wolfie29177
Member #: 476
Thanks lads. I've got a wideband AFR sensor and gauge and will be taking it off to a rolling road once its got some miles on it so hopefully I wont total it. Think I'll stick to 15psi max to be safe
