| Home > Help Needed / General Tech Chat > Edis 4 issue | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
26th Apr, 2015 at 01:55:12pm
Hi guys,
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
26th Apr, 2015 at 02:01:46pm
if i recall i ended up putting the ballast resistor in for the edis module after similar issues, i stand prepared to be slated/corrected, think i got the wiring loom off an escort Edited by stefaz on 26th Apr, 2015. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
26th Apr, 2015 at 03:28:51pm
Check the crank position sensor. |
26th Apr, 2015 at 03:56:44pm
The distance from the trigger wheel? I'm guessing the polarity must be fine due to it starting and running. |
26th Apr, 2015 at 07:13:34pm
Check the distance, but also it could just be duff or picking up interference. Is it used or new? |
26th Apr, 2015 at 07:25:01pm
On 26th Apr, 2015 metroturbo said:
Check the crank position sensor. I had an issue with an intermittant starting issue caused by a faulty sensor. On 7th Oct, 2010 5haneJ said:
174 Posts Member #: 9128 Advanced Member |
26th Apr, 2015 at 08:43:15pm
Check you've still got a least 12 volts, it won't work with anything less. |
27th Apr, 2015 at 12:08:05pm
That's interesting to know. That could well be the problem as the battery's not been charged for a while. I shall check and report back. |
28th Apr, 2015 at 04:48:10am
Not sure what you have in the way of trigger wheel, but make sure it has not slipped or moved. |
28th Apr, 2015 at 07:27:27pm
Hi lads,
Edited by 1275min on 28th Apr, 2015. |
29th Apr, 2015 at 08:54:27pm
The laptop I use for mine is ancient with a knackered battery. Just get yourself a inverter and fit a cig lighter. |
