| Home > Help Needed / General Tech Chat > Strange problem with spark plugs/engine | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
27th Apr, 2015 at 12:52:01pm
Hi all Iam having a strange problem with my motor It runs good on champion n9yc after fouling problems with ngk bp7es & bp6es but here's were the strange bit comes in the plugs get worse from cylinder 1-4 ie 1 looking purfect light brown deposit
27th Apr, 2015 at 02:57:47pm
if your wetting ngk bpr6es you are stupidly rich Yes i moved to the darkside |
27th Apr, 2015 at 03:03:36pm
Just on 1 cylinder tho #4 #1 is fine that's me strange problem plugs get worse from 1-4 |
28th Apr, 2015 at 07:12:27am
What set up are you running?
28th Apr, 2015 at 08:30:12am
Swopped plugs & leads round still the same |
28th Apr, 2015 at 11:23:01am
the cylinder in question is burning oil, (weak or stuck oil controll rings) the fouling and wetting is oil not fuel. just a thought?
Edited by evolotion on 28th Apr, 2015. turbo 16v k-series 11.9@118.9 :)
28th Apr, 2015 at 11:48:21am
It's got total seal rings the heads just had all the valve seats recut new stem seals all guides are good & the plugs get worse from cylinder 1-4 there's not just 1 cylinder with a problem just 4 is the worst |
28th Apr, 2015 at 11:51:34am
Like i say just a thought, I had a 1380 that was doing similar, used to have to clean the plugs every few days and it was weak oil controll rings. one cylinder would always foul, with the others not too far behind. turbo 16v k-series 11.9@118.9 :)
28th Apr, 2015 at 04:41:31pm
Yes I would agree with mr evolotion, Scott the total seal rings are IMO not any way as good as a rebore and new omegas,
