| Home > Help Needed / General Tech Chat > 1310 build | |||||||
10 Posts Member #: 10962 Member |
30th Apr, 2015 at 07:33:54am
Right guys my 1310 has dropped a ring and is due for a refresh after 16k miles so I managed to grab a t3 in good order on the metro manifold with a turbo inlet, carb and plenum for 120 quid which I was happy with.
167 Posts Member #: 11091 Advanced Member |
1st May, 2015 at 11:13:46am
i'd put some omega cast pistons in;
1st May, 2015 at 01:46:14pm
sorry i dont know what they are yet as im still in Iraq, im home on the 14th so will pick up the new mini then pull the head off the old 1 and check. is it possible to get 10cc +40 pistons?
1st May, 2015 at 03:31:27pm
You can get +0.040" Omegas from MED.
2nd May, 2015 at 03:46:32am
Thanks Benross, also how much would you charge to enlarge the chambers to 28 ish cc on my head and fit suitable valves for turbo, it's currently 35.5 inlets.
2nd May, 2015 at 07:55:22pm
You need to CC the head first. All advice before that are only guesses. On 13th Jul, 2012 Ben H said:
2nd May, 2015 at 08:59:45pm
As V says. Also if the heads been skimmed by much at all you'll struggle to get 28cc from the chambers.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
2nd May, 2015 at 09:28:24pm
Benross? Am i missing summin?
On 2nd May, 2015 holmesy9 said:
Thanks Benross, also how much would you charge to enlarge the chambers to 28 ish cc on my head and fit suitable valves for turbo, it's currently 35.5 inlets. Regards, Connor On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
