Home > Help Needed / General Tech Chat > Trigger wheel, quick check
jonny f
Member #: 9894
Dorking
Hi guys, am i right in thinking i have this bang on, 90deg before tdc.
Its at TDC (accurate with a DTI)
So 90 deg before TDC would be indicated by the red tooth which needs to be removed?
http://autosportlabs.net/images/1/1c/Edis_wheel.gif
Edit: nevermind I'm tired, the tooth you marked to take off looks correct
Edited by Carlzilla on 30th Apr, 2015.
jonny f
Member #: 9894
Dorking
Thanks dude.
Looks the right one according to that GIF.
philc
Member #: 1346
bromsgrove
just a thought, I am not saying you will have this issue, but I had a similar trigger wheel and it kept coming loose, maybe a little loctie maybe of benefit.
jonny f
Member #: 9894
Dorking
Thanks Phil :).
I'm already on it, I have a similar pulley/bolt on the car at the moment. Made sure it was very clean and put a little 243 on it. Had no problems.
