| Home > Help Needed / General Tech Chat > fresh rebuild getting hard to turn over | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
3rd May, 2015 at 08:36:34am
Like title say. Rebuilding a 1275 metro engine with total seal rings. Fitting the crank it turned normal (litke friction felt but normal ) then first piston in and torqued down it got a bit harder... second in and torqued i could no longer turn it on the cranck itself. Gad to put on the cranck pulley to turn it. Do get it turned but needs quit some efford. ( can turn it with one hand) Didn't do the to others yet ( ring tensioner broke.. cheap ebay thing ) but by the time they will be fit and expecting to go stiffer by the sale rate i think i only wil be able to turn it with the flywheel on.
3rd May, 2015 at 08:41:34am
Have you had your crank reground? |
3rd May, 2015 at 08:51:50am
No cranck whas like new. (Engine only had some 40000kms from new. New bearings all round though. you can do anything if you set your mind to it...
3rd May, 2015 at 08:56:23am
take one conrod off at a time i might be a oversized bearing |
3rd May, 2015 at 09:45:10am
Hm. I'll swap one round. They are glyco bearings. Std size. If i mesure them they are all the same thickness though.
3rd May, 2015 at 09:51:53am
its always worth doing a pre assy without the rings to check for crank tightness.
3rd May, 2015 at 09:51:55am
3rd May, 2015 at 10:03:57am
I always trial fit the rods onto the crank before fitting the crank. You can check they turn freely and check side clearances at the same time.
3rd May, 2015 at 10:19:06am
Crank only torqued up, it should literally turn with only a finger and thumb, no effort at all.
Edited by stevieturbo on 3rd May, 2015. 9.85 @ 145mph
3rd May, 2015 at 10:27:40am
Cranck turned free. You can feel it is between bearings but thats it. Now i did the following.
Edited by Rammie2000 on 3rd May, 2015. you can do anything if you set your mind to it...
5th May, 2015 at 10:25:46am
imo
5th May, 2015 at 04:10:43pm
Anyone thoughts on the cap if i could is good like that. Know it isn't its original one but works like its supposed to. you can do anything if you set your mind to it...
5th May, 2015 at 04:10:46pm
5th May, 2015 at 08:38:40pm
You cant just throw a random cap on and hope its ok. Take your rods to a machine shop, point out the problem rod, ask them to check and offer a solution. The machine shops i use have setups to hone rod big ends. turbo 16v k-series 11.9@118.9 :)
5th May, 2015 at 11:14:35pm
If there is a problem with the rod, just replace the rod. 9.85 @ 145mph
6th May, 2015 at 09:11:07am
Rammie, you can't use the caps if you've mixed them up, even if they appear to turn freely.
Edited by PhilR on 8th May, 2015. |
6th May, 2015 at 09:37:28am
Okey great tip there. So if those arent matching ill have to have it rehoned. you can do anything if you set your mind to it...
6th May, 2015 at 10:07:57am
Take your rods and crank out.
Edited by MikeRace on 6th May, 2015. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th May, 2015 at 10:27:51am
I got them all out and back in again like said above. There is only one trouble maker. All the rest turns and rotates as it should. If i check it as you say none of the 2 caps ( neighter the one that was on there or the one i have on there now wich it does rotate with have an edge. Only the original one is binding up. ( even put together without being on the cranck it needs to be torqued to close up. Ill go and get a magnification glass like said. Also rang the machine shop so tomorrow they can mesure it for roundness. Did see that the bearings i tryed the original cap with have quit some rub marks one 1 side just from trying to turn it by hand ( yes they were lubricated)
On 6th May, 2015 MikeRace said:
Take your rods and crank out. Fit the caps to each rod feel with your finger nail for an edge. if it has one you know its wrong. Do the same with the Mains. Fit them and feel for an edge where they join. Once they all feel OK. Fit the Crank and Road back in the engine. And torque section down at a time checking for binding. So start with Main Caps. Check for binding. Then do Each Conrod checking between each one. You may have a crushed locating ring, or an oval-ed cap. you can do anything if you set your mind to it...
