Home > Help Needed / General Tech Chat > actuator pressure
clubbie70
Member #: 8935
netherlands
My new gt1752 arrived......
took the actuaotor off to pressure test it
disconected it starts to open around 13 psi and fully open at 30 psi
is this correct??
i used 2 different gauges ...both the same reading...
nrs on actuator
4050712
BA-165 S8505
Im sure the pressure is when the valve starts to crack open, looks like a 12psi or 1bar(14psi) actuator
The gt17 ( if from a saab) should be around 4psi
Chinese?
oli79
Member #: 8480
no ive eaten thanks
On 4th May, 2015 theoneeyedlizard said:
Chinese?
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
5.5 psi base setting on gt17's i have used.
evolotion
Member #: 83
Glasgow, Scotland
if its off a diesel itll start to crack open at 14psi+ as a general rule with "half a hole" preload(3mm or so) the boost it cracks open at is the boost the engine will run.
Denis O'Brien.
