Home > Help Needed / General Tech Chat > Wheels and brakes
ian2000t
Member #: 2764
Halesowen
On my car I've currently got 13" Starmags which I do really like because the rest of the car is quite understated, they set it off well. But, that's with the later grille and sportspack arches. I run vented Metro 4 pots at the moment, which are great until one of the cylinders rusts. They need rebuilding with stainless pistons really.
Thing is once my mini is done I'll have a mk1 grille and possibly body colour (old English white) Group 2 wide (or similar). I'm not sure whether the 13" Starmags will still suit it. Dunlop's would look good I think, but they are only in 10/12" and aren't particularly wide.
I don't think I would ever really go for 12's, but now I'm wondering if 13's are the right way to go, or if I should start looking at 10's as I'm going more classic with the grille and arches. I would still want something with quite a wide, deep dish look (6", or maybe 7"). Maybe even body colour banded steels (professionally done).
So, what are my options for brakes? I know there are lots of expensive alloy 4 pots, but I've heard mixed reviews. Has anyone on here done the Fiesta conversion (single pot 7.9 solid disc)? If so, how does it compare with the Metro vented 4 pots and 8.4 vented disc?
Also any advice or pictures on the 10/13" wheels? Was hoping for some inspiration at Himley, but the only cars I thought looked really nice with 13's all had sports packs.
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
I ran fiesta brakes for years, they were great, I ran groved front discs, ferodo premium pads, 1275 gt RWC and a yellow tag mc.
They pull the car up well, but not all 10" wheels fit with them.
I will say I used all new parts except for the hubs and carriers.
Edited by gr4h4m on 11th May, 2015.
If it helps Ian, when i swapped from rebuilt 8.4s with blackstuff pads, to brand new 7.5s with mintex m1144 pads, i actually felt that the braking was all around better. But i guess theres less disc to soak away heat under heavy braking is the downside.
beejay
Member #: 10785
Derby
I've got fiesta brakes on solid 7.9 inch discs, standard pads. No issue with them, they seem as as good as I remember the 8.4inch discs to be. I used second hand calipers from a mk1 fiesta, some bits were difficult to get hold of to rebuild them, apart from that it was a straightforward conversion.
ian2000t
Member #: 2764
Halesowen
Ok thanks. If I can get some cheap enough, I might get some in case I decide to go to 10's.
Would I need calipers from a solid, or vented disk Fiesta?
