| Home > Help Needed / General Tech Chat > Wiper Motor Relocation | |||||||
107 Posts Member #: 2556 Advanced Member Southport, Merseyside |
12th May, 2015 at 03:35:49pm
Hello!
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
12th May, 2015 at 04:21:22pm
I have in past, and a few on here have... i just put motor same place just inside of bulkhead.. then its just angling and threading windy bit thru On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
12th May, 2015 at 04:30:58pm
As Dave said.
12th May, 2015 at 05:30:10pm
how did you guys fasten it to the inside of the bulkhead? Did you have to disconnect the motor from the wiper 'rod' bit or will it go through as a complete assembly? |
12th May, 2015 at 06:27:55pm
Take it apart, just slides off.
12th May, 2015 at 06:52:18pm
Thanks for the advice!
12th May, 2015 at 10:52:54pm
Just remembered its easier to leave the inner wire and the first tube in the motor, thread it through from inside and then put all the other bits on.
![]() 1751 Posts Member #: 10190 Post Whore belgium |
13th May, 2015 at 09:34:47pm
while this is at it. i have a question about this to. i have a engine bay heater motor but now realize that the hole where the air tube goes trough sits where the wiper motor sits. ( aprox) could the whole system cope with a 30 degree extra bent so the motor lays down more? or would the inner cable brake to fast? you can do anything if you set your mind to it...
13th May, 2015 at 10:42:41pm
13th May, 2015 at 11:26:37pm
On 13th May, 2015 Rammie2000 said:
while this is at it. i have a question about this to. i have a engine bay heater motor but now realize that the hole where the air tube goes trough sits where the wiper motor sits. ( aprox) could the whole system cope with a 30 degree extra bent so the motor lays down more? or would the inner cable brake to fast? I can't see why not, mine has quite a tight bend in it. |
14th May, 2015 at 05:49:43am
Yes eum... snail type? The heater is in the car but the motor to blow the air trough it sits in the engine bay.
On 13th May, 2015 D4VE said:
Engine bay heater motor? http://www.somerfordmini.co.uk/eshop/index...page=page&id=98 In first pic botom right is that external motor. Edited by Rammie2000 on 14th May, 2015. you can do anything if you set your mind to it...
14th May, 2015 at 06:45:44am
Ah i see... so the matrix is in the car but fan in the bay? On 24th Oct, 2015 jonny f said:
14th May, 2015 at 07:31:56am
On 14th May, 2015 D4VE said:
Ah i see... so the matrix is in the car but fan in the bay? you can do anything if you set your mind to it...
14th May, 2015 at 07:32:02am
14th May, 2015 at 07:13:18pm
I once saw a mini at Hudds Mini spares, and the motor was down right in the bottom of the passenger footwell? Fook knows how they had managed that. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th May, 2015 at 08:35:36pm
Sure that werent just a new motor just brought n thrown in the footwell On 24th Oct, 2015 jonny f said:
15th May, 2015 at 08:17:48am
if i rember ill take a pic of mine i didnt shorten it or any of that jaz just bent the outer tube bu hand and drilled a 20 or so mm hole then made a quick sloppy bracket to mount it the hardes part was reaching up under the wheel arch and in behind the dash good thing ive got long arms |
