| Home > Help Needed / General Tech Chat > New brake system | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
14th May, 2015 at 07:32:35pm
Evening folks...
14th May, 2015 at 07:35:00pm
Correct your location please as requested. Last polite request.
14th May, 2015 at 07:45:05pm
On 14th May, 2015 Tom Fenton said:
Correct your location please as requested. Last polite request. Now, whilst your here Tom... back to my question... |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
14th May, 2015 at 08:02:17pm
Maybe try the link on the second item you posted, what's this diagram tell you?
Edited by oli79 on 14th May, 2015. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
14th May, 2015 at 08:10:10pm
And this https://minispares.com/catalogues/classic/C...pes.aspx?1~9~78 On 18th Oct, 2013 apbellamy said:
14th May, 2015 at 08:27:12pm
Ah I see... yes was a we bit confused as some of the master cylinders had 2 outlets for the duel line. But, correct me if I'm wrong, the cylinder I want to use is single line and as a result I'd need one of these..
14th May, 2015 at 08:35:35pm
Given the choice I would choose the twin master and use the H shaped bias valve on the bulkhead. If one side of your system fails at least you have done brakes left to stop with.
14th May, 2015 at 08:51:52pm
Right well you've about got it, there's single line with a rear bias valve, or there's a duel line either yellow tag or servo mc which use the bulkhead compensator. There is toms recommendation^ there's also quite a few threads you will find with a search as to other people's preferences, possibly even a much cheaper alternative to the bias valve you posted there. On 18th Oct, 2013 apbellamy said:
14th May, 2015 at 08:58:55pm
Yes I think I do have it now.. I think I like the idea of Tom's recommendation as it makes sense if one side fails the other is left working.
14th May, 2015 at 09:01:36pm
That's a single line cylinder and a duel line valve. As Tom says either get a single line valve or a duel line cylinder. Duel is probably safer! |
14th May, 2015 at 09:01:45pm
14th May, 2015 at 09:08:21pm
Yes Slater, I think I'm home and dry... one of these...
Edited by evad1980 on 14th May, 2015. |
