Home > Help Needed / General Tech Chat > duplex timming chain / cam
tony 69
Member #: 10548
chesterfield
Hi guys quick question Im finally getting back to my engine build.
Im fitting a duplex timing chain however after fitting the large cog on the camshaft end I get a small amount of play when i pull the cog outwards from the engine. I've been told there should be none is this correct about no play or am I allowed to have some play. Also I know I need countersunk bolt under small cog any ideas where to get these from or the size of bolts I need to find.
Thanks Tony*indifferent*
PhilR
Member #: 10034
Birmingham
screws...
http://www.minispares.com/product////Camsh...ary/AEA687.aspx
check your cam thrust / retainer plate for wear....
http://www.minispares.com/product///Block/AHU2379.aspx?1001
tony 69
Member #: 10548
chesterfield
Cheers Phil been on and ordered a set also ordered a new thrust washer too for that price no point messing
Cheers again *Clapping*
Buy a Haynes manual while you are at it.
