| Home > Help Needed / General Tech Chat > Ring gear location verto vs pre verto flywheels. | |||||||
17th May, 2015 at 07:49:57pm
I bought a Denso pre-verto, inertia starter motor a while back now, and have only just got round to testing it. The issue seems to be the solenoid wants to kick back, instead of staying in the fully extended position, causing a loss of starting, and plenty of 'clicking'. I have replaced the solenoid contacts, to check they are ok and wondering whether the issue is not routed in the starter but the flywheel i'm using to test it on.
17th May, 2015 at 07:53:11pm
I would have thought the verto ring gear is further out as the bulk of the flywheel is away from the transfer case on a verto, but close on a pre verto. On 11th Feb, 2015 robert said:
18th May, 2015 at 04:06:18pm
The inertia (mostly pre verto) and pre engaged (mostly verto) ring gears have different tooth cpunts and cannot be interchanged between types, you need the starter and ring gear to match if you don't have already. I have a preverto ultralight with a pre engaged ring gear for example. On 26th Jan, 2012 Tom Fenton said:
18th May, 2015 at 06:26:05pm
As above, different tooth counts, so the starters cannot be swapped. 9.85 @ 145mph
18th May, 2015 at 06:59:54pm
Think pre verto is 127 teeth and verto is 130 something to |
18th May, 2015 at 07:00:40pm
18th May, 2015 at 07:00:41pm
18th May, 2015 at 07:01:38pm
18th May, 2015 at 07:07:57pm
Seems to be some confustion here.
