| Home > Help Needed / General Tech Chat > Does it need a gasket? | |||||||
![]() 71 Posts Member #: 2328 Advanced Member Nr Newmarket, Suffolk |
20th May, 2015 at 07:45:07am
Hi guys,
100% BMW Free |
20th May, 2015 at 08:22:58am
well if it helps, when I removed the one from mine last week, it had a gasket fitted; not sure I've another to refit yet but I'd likely want to re-install something to ensure it is 'gas tight' |
20th May, 2015 at 10:44:51am
That's what i thought. Is that one likely to be a paper one? I had a quick look at the part last night but it was dark! I think i may have a few bits of gasket left on it! 100% BMW Free |
20th May, 2015 at 10:45:33am
mine was paper |
20th May, 2015 at 11:34:47am
On 20th May, 2015 Guennie said:
Hi guys, I'ts been a while since i posted! I've just had my turbo rebuilt and it's ready to fit. While it was away the guys obviously removed the bolt on bits that they don't deal with, (oil return, exhaust elbow, etc). Now i have it back they've provided me with the paper gaskets for the oil return and the metal gasket between the exhaust manifold and turbo. I've also got an exhaust elbow gasket on its way to me now. My question is. Do I need a gasket on the inlet side of the turbo between the turbo housing and the "extension/connection" piece (where the inter cooler pipe fits to)? Brilliant description i know.... If so, what would you guys recommend? I don't even know what to search for! Cheers, Simon If you're referring to the compressor discharge adaptor, the 2 bolt flanged bit. OEM would have used a gasket. But no, it is not essential at all. You could use some sealer instead, just make sure both faces are flat and clean. I'd prefer it with no gasket. 9.85 @ 145mph
20th May, 2015 at 02:17:03pm
Thanks for the replies. Yes the "compressor discharge adapter" is what i was referring to, in less technical terms! Sounds good. I'll sort something tonight.
100% BMW Free |
