| Home > Help Needed / General Tech Chat > Running in new gearbox? | |||||||
21st May, 2015 at 09:00:09pm
Hi
My build thread..
21st May, 2015 at 10:12:51pm
6000 miles is very far to go between changes in a mini in my opinion.
Edited by jonny f on 21st May, 2015. |
21st May, 2015 at 11:19:37pm
There should be nothing in the gearbox that needs 'running in'
22nd May, 2015 at 07:47:44am
Yep. CVT from the off. |
22nd May, 2015 at 08:01:49am
Tbh I don't do more than 3000 miles a year anyway.
My build thread..
22nd May, 2015 at 08:07:19am
On 21st May, 2015 Sprocket said:
There should be nothing in the gearbox that needs 'running in' The 'running in' of an engine is all about the rings and bore. I don't know Col, surely if its a brand new gearkit there will be some metal created as the gear teeth wear in to one another? Agree with what is said above though, change it as often as possible!
22nd May, 2015 at 08:49:08am
depends on the quality of the gear set and shafts i know the kit i bought was disappointing to say the least bores had taper and the flanks looked like crap i did some lapping to sort the bores but couldn't help the teeth so ive done a bunch of oil/filter drops just to be safe
22nd May, 2015 at 09:11:14am
I agree with the above and in your case I would do a few oil changes, and don't put tesco cheapo in there my advice is shell rimula r4 x 15/40
22nd May, 2015 at 02:38:56pm
The only thing I can see that might need to bed in a bit are the baulk rings but judging by how long they last nowerdays I'd prefer them to bed in as slow as possible lol |
23rd May, 2015 at 04:02:55pm
There should be nothing in the gearbox that needs 'running in' The 'running in' of an engine is all about the rings and bore. I don't know Col, surely if its a brand new gearkit there will be some metal created as the gear teeth wear in to one another? I would tend to agree with some of the stuff I have seen recently, but then, that is surely a quality issue. Looking at it another way, any transmission that does not share the engine oil is filled with EP90 or similar from the off and not changed for quite some considerable time, why should the Mini gearbox be any different. On 26th Oct, 2004 TurboDave16v said:
18 Posts Member #: 11028 Member |
23rd May, 2015 at 08:24:55pm
Engine oil isn't gear oil, so it's going to behave slightly differently. The difference being there is no residual lubrication in non-gear oil under very high pressures, which very sharp edges create. Personally, I'd load it up with oil, run it and then change it slightly early, along with taking the swarf off the drain plug.
