| Home > Help Needed / General Tech Chat > not engageing gear? please help | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
22nd May, 2015 at 08:11:59pm
Hey you guys... my friend has a mini and its got us all a little stumped? But i know for a fact with fresh brains especially TM brains it should hopefully be resolved (and by sun 31st too as were booked in for the track time at snetterton at the retro show)
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
22nd May, 2015 at 08:29:45pm
Can any gears be selected when the engine isn't running? Is the clutch fully working now and disengaging the box, or is it grinding into 3rd also? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd May, 2015 at 08:58:48pm
Yes all gears can be selected when not running, will find out about 3rd = no apparently now after all the new bits he cant select none when running Edited by D4VE on 22nd May, 2015. On 24th Oct, 2015 jonny f said:
23rd May, 2015 at 07:57:00am
how far is the slave push rod travelling, how far is the thrust bearing carrier traveling, |
23rd May, 2015 at 08:15:24am
is the flywheel catching on the c clip? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
23rd May, 2015 at 09:38:53am
Primary gear seized on to flywheel? If something is worth doing, it's worth doing half of. |
26th May, 2015 at 10:15:27pm
My friend and i would like to thank everyone for there help and suggestions... he told me tonight that he had cured it! After replacing the noisy thrust n worn out master n slave, apparently the pin to the pedal was just catching the housing enough not give full travel!? 'Doh'! But an easy fix and atleast he'll be joining me out on snettertons track this sunday On 24th Oct, 2015 jonny f said:
27th May, 2015 at 08:40:42am
yeh! |
