| Home > Technical Chat > Petrol? | |||||||
31 Posts Member #: 590 Member Solihull |
25th Aug, 2005 at 07:23:27pm
Another day another problem...... It was like that when i got there! |
25th Aug, 2005 at 07:28:19pm
It could be the carb itself... there are a few places it can leak.
AlexF |
25th Aug, 2005 at 11:00:48pm
As AF says - it's the carb.
26th Aug, 2005 at 07:41:59am
and would you believe it i have one in stock |
27th Aug, 2005 at 02:29:23pm
Thanks guys i have solved the problem now. You're right it was the o ring at the bottom of the carb...plus the fact that my crappy engine mount ( yes, mount ie 1) has let my carb bash against the bulk head and the bottom plate of the carb was warpped! lol
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
27th Aug, 2005 at 05:59:14pm
Have you got the extra steadies going to the back of the subframe, coming off the gearbox casing ?
28th Aug, 2005 at 06:59:49am
weld the ultimate steady to the side of the turbo box near the radiator works very time. always looking for them bigger bunches of bannanas |
30th Aug, 2005 at 09:49:58am
Phil
30th Aug, 2005 at 10:54:32am
Yes the ultimate head steady is what you want, though as you know you will have chopped off the area it usually bolts to, so you'll need to fabricate a bracket for the bulkhead end. If you do that I think you'll find it loads better.
31st Aug, 2005 at 01:26:03pm
The head steady is the good, but adding the others as well can only help. Mine were Minispares items.
SO i suppose a welding a ultimate is more than possible..
