Home > Help Needed / General Tech Chat > How to get grind marks out of body work before spraying ?
Jakej08
Member #: 10398
Swansea , Wales
Hi I've got a classic mini that I intend on restoring, the body of the mini is in good condition no rust or dents but there loads of grinding marks where the previous owner removed all the paint. Any ideas on how to get rid of them . Possible something like a high build primer or body putty ? Any advice would be appreciated.
Callum
Member #: 10396
Stoke-on-Trent
Depends how deep they are, you will get away with a high build primer if they are only light scratches
High build primer, thin dusting of a dark colour paint as a guide and then block sand the whole car. This will then show up the low spots. The high build will usually sort the minor scuffs, but a quick skim of filler sanded back before you apply any paint wouldn't go amiss in areas you know the scuffs are a bit deeper.
PhilR
Member #: 10034
Birmingham
If any scratches are too deep for high build primer, use body filler thinned down with acetone.
