| Home > Help Needed / General Tech Chat > engine stalling when clutch depressed | |||||||
![]() 218 Posts Member #: 9213 Senior Member Scotland |
25th May, 2015 at 09:49:16am
Hi guys,
25th May, 2015 at 10:29:37am
99% certain it will be the thrusts
Yes i moved to the darkside |
25th May, 2015 at 11:25:14am
I'd suspect thrusts too but before you do, which clutch set-up are you using? I had issues with the double grey doing similar things (didn't actually stall it to be fair) but it all disappeared when I swapped to the verto setup. |
25th May, 2015 at 11:39:55am
M E D X-Lite steel flywheel
25th May, 2015 at 02:46:05pm
Yep I had this put them in the wrong way cost me a crank working out what it was ! I have started posting on Instagram also my name on there is turbomk1golf
25th May, 2015 at 07:09:38pm
Also I'm sure you know, but never start the engine with the clutch down On 7th Oct, 2010 5haneJ said:
25th May, 2015 at 09:49:51pm
A quick double check to make sure your clutch isn't throwing too far before you strip it down would be my first stop. Does sound like crank/thrusts though unfortunately. On 20th Oct, 2015 Tom Fenton said:
23rd Aug, 2015 at 06:09:02pm
Finally got round to stripping the engine back down and when i got to the crank, the thrust bearing face had been completely stripped and there were copper bits everywhere.
23rd Aug, 2015 at 07:56:30pm
I'd source another crank and stick that one on the shelf for a rainy day. If something is worth doing, it's worth doing half of. |
23rd Aug, 2015 at 08:32:31pm
2nd'ed,
24th Aug, 2015 at 11:27:03am
struggling to find anything on the 2nd hand market and there doesnt seem to be a massive amount of choice for new either. I dont want to splurge on billet so seems like one of my only options is minisport and something like this:
24th Aug, 2015 at 11:40:33am
Shop around I'm sure you will find something more competitively priced than that! Unless you want a wedged crank that is. If something is worth doing, it's worth doing half of. |
24th Aug, 2015 at 05:45:34pm
Fastcarl does good crank, simple wedge and heat treat should be a piece of cake. On 7th Oct, 2010 5haneJ said:
24th Aug, 2015 at 05:52:20pm
There's a standard reground crank on tmf if it's of any use. I run a supercharger and I don't care the TB is on the wrong side.
29th Aug, 2015 at 12:43:28pm
Local mini specialst has a standard a+ crank that he says is better spec than i have here. Not sure how it's better?
29th Aug, 2015 at 02:00:41pm
Unless it's heat treated or a 6581 then an a plus crank is an a plus crank On 7th Oct, 2010 5haneJ said:
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
29th Aug, 2015 at 03:02:40pm
Vizard says cam6232 is stronger that 12G1505!!
On 29th Aug, 2015 minimole23 said:
Unless it's heat treated or a 6581 then an a plus crank is an a plus crank nky_84 you also this option http://www.minisport.com/cam6232-genuine-b...crankshaft.html Pedro Silva
29th Aug, 2015 at 07:19:45pm
Minisport!?
Edited by Sprocket on 29th Aug, 2015. On 26th Oct, 2004 TurboDave16v said:
29th Aug, 2015 at 07:21:49pm
Bliley, the price on those have gone up. I have one on the shelf I paid 160 notes for.
On 29th Aug, 2015 sim_ou_nao said:
Vizard says cam6232 is stronger that 12G1505!! On 29th Aug, 2015 minimole23 said:
Unless it's heat treated or a 6581 then an a plus crank is an a plus crank nky_84 you also this option http://www.minisport.com/cam6232-genuine-b...crankshaft.html On 26th Oct, 2004 TurboDave16v said:
29th Aug, 2015 at 07:26:43pm
I think 255£ with bearings it´s a good price, well, if the quality from the crankshaft is good!
Pedro Silva
30th Aug, 2015 at 06:31:48pm
Unless it's heat treated or a 6581 then an a plus crank is an a plus crank I assumed you already had a6232 in there. As long as the fillett radius are good with an a plus then you should be fine. On 7th Oct, 2010 5haneJ said:
30th Aug, 2015 at 08:19:22pm
I think 255£ with bearings it´s a good price, well, if the quality from the crankshaft is good! |
