| Home > Help Needed / General Tech Chat > megajolt and tacho | |||||||
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
27th May, 2015 at 09:12:04am
My current tacho runs from the coil. Having recently purchased a megajolt and reading up on it. Is it an easy fix to run my current tacho from megajolt? Wondering what you guys do. Also what cable are you using as my megajolt seems to have a smaller port than the serial port I was expecting.
BHP sells engines, but Torque wins races! |
27th May, 2015 at 09:40:59am
What tacho do you have? My build thread..
27th May, 2015 at 09:50:23am
There's a few options, you can use one off the mj unit, there's a way of using it from the coil pack and another from the edis, autosportlabs site list all the ways, might just have to try each one in turn to see what works and reads correctly. On 26th Jan, 2012 Tom Fenton said:
27th May, 2015 at 10:35:24am
Nice one. Cheers.
27th May, 2015 at 10:35:27am
Nice one. Cheers.
17 Posts Member #: 9903 Member Northern California |
27th May, 2015 at 10:45:49am
There are basically two types of electronic tach: voltage sensing, and current sensing. Those which run in series with the coil are current sensing. They have a loop of wire passing through a funny little bracket on the back that then goes to the coil. Voltage sensing tachs have a single wire that ends at the tach. While it is possible to modify a current sensing tach to accept a voltage signal, it is not a trivial task. Try this link:
27th May, 2015 at 11:40:54am
Thats some helpful info, cheers Frog.aye
27th May, 2015 at 11:42:00am
This one followed by a USB adaptor?
27th May, 2015 at 11:44:59am
Also found this Gucci bit of kit
![]() 428 Posts Member #: 10128 Senior Member Dorset |
29th May, 2015 at 11:26:00pm
I bought the tacho driver from trigger wheels (http://trigger-wheels.com/store/contents/en-uk/d33.html) but turned out I didn't need it, PM me your address and you can have it if it's of any use.
