Home > Help Needed / General Tech Chat > loctite headstuds?
madonminis
Member #: 9371
East Yorkshire
Is this a yay or a nay? Just removed my head and some of the studs worked loose rather easy. I have some studlock 270. Thoughts from the pro's?
Matt
Ive never needed to, also 270 is pretty strong so only use a dot.
madonminis
Member #: 9371
East Yorkshire
They're ARP studs. Don't like the idea of getting them stuck and running the thread with stud removal tools. Will probably leave it.
tadge44
Member #: 2500
Buckinghamshire
I forget where, but I read that studs should be screwed in only finger tight.
It is not a problem if they unscrew with the head nut any way.
slater
Member #: 1291
Suffolk / Birmingham
Nay follow ARPs instructions. They supply lube with the kit do they not?
madonminis
Member #: 9371
East Yorkshire
Second hand studs so couldn't tell you
steve1275
Member #: 951
Bromsgrove
Only use it on the front stud of an 11 stud setup to stop the coolant leak up the thread...
'Where does the engine go?'
Mike-998
Member #: 9774
Buckinghamshire
And even then I'd use thread sealant (535??) not 270 locktite, or you'll never get the thing out. If you don't need the sealant though, they're just installed finger tight.
