Home > Help Needed / General Tech Chat > Megajolt won't advance timing and map sensor isn't working
tomostrash
Member #: 10334
Staffordshire
Hi, I've just installed a megajolt to my mini turbo and it seem to have some issues ! The timing is stuck and won't auto adjust and the map sensor isn't working. Can anyone help?Dean
Sounds like connection issues with mjlj
The edis module will start and run the car in limp mode on its own with static timing
How do you know the map sensor is not working?
tomostrash
Member #: 10334
Staffordshire
If I rev the car or suck on the vac pipe the gauge doesn't move
tomostrash
Member #: 10334
Staffordshire
I didn't shield the wires from the edis unit to the MJ may be that's why!?
sounds like the jolts not getting power, even with no rpm signal you should see the MAP gauge move in the software.
if you were seing the gauges move, bit no advance then it would be the signal from the jolt to the edis, or the edis itself.
tomostrash
Member #: 10334
Staffordshire
Green light is on and revs are showing on the laptop! I did purchase a tps MJ and fitted a map sensor with resistors.I now know why it's took me two years to fit it!
Are you sure the software can see the MJ?
tomostrash
Member #: 10334
Staffordshire
Yes the laptop is talking 100%
In that case im almost certain you have to flash the mjlj to tell it its now got map sensors instead of tps
good call
tomostrash
Member #: 10334
Staffordshire
I'm on it! thanks for your help boz
tomostrash
Member #: 10334
Staffordshire
New firmware programme won't load! This is getting a pain in the arse
wolfie29177
Member #: 476
The Black Countraaaaay
If it's been converted from TPS to MAP it needs resetting as it wont recognise the MAP signal
Masturbation is not a crime its a hobby
tomostrash
Member #: 10334
Staffordshire
Tried two computers and firmware software won't load I'm beginning to wish I left it alone
wolfie29177
Member #: 476
have you checked the MJ board in case any solder has become brittle or anythings come loose?
tomostrash
Member #: 10334
Staffordshire
Yeah I checked it and resoldered just in case
