| Home > Help Needed / General Tech Chat > Oil T piece and threads | |||||||
![]() 71 Posts Member #: 2328 Advanced Member Nr Newmarket, Suffolk |
31st May, 2015 at 11:41:13am
Hi guys,
100% BMW Free |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
31st May, 2015 at 11:56:21am
The block thread should be 1/8 NPT, as should the threads on the T piece.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
31st May, 2015 at 12:08:59pm
The adaptor for the oil gauge can screw into the block nicely, indicating that both threads are 1/8npt. The adaptor can also screw into the female threads of the t piece. The male thread on the t piece appears to be tapered though?! 100% BMW Free |
31st May, 2015 at 12:09:03pm
Double post! Edited by Guennie on 31st May, 2015. 100% BMW Free |
31st May, 2015 at 12:23:03pm
It sounds like the threads on the T-Piece are damaged or were not machined correctly. The T-piece should be a tapered thread, which is why it doesn't require copper washers to seal. Your other unions and adapters should also be tapered.
31st May, 2015 at 01:57:41pm
1.5 turns and stopping sounds like the male thread is 1/8 BSP rather than the required NPT. |
1st Jun, 2015 at 09:42:06am
Thanks for the reply's guys. Turns out I've been a bit of a moron! Somehow I managed to fit the t piece incorrectly years ago, and amazingly avoided any leaks!!!
100% BMW Free |
