Home > Help Needed / General Tech Chat > Microsquirt Woes
Fellas, Im ragging my wig out with this thing.
Purchased a microsquirt brand new from Trigger Wheels.
Firstly i tried a USB to Serial but had no joy what so ever. So managed to source a PC with a Serial Port.
Put the Port to 115200 baud rate and fired up Megatune, when I connect the MS i get
"Controller code version does not match signiture in Megasquirt-ii.ini
Expected "msii Rev 2.88600
Recieved ""(from controller)
WHAT DA FOOQ
Tried Port checker and get "no response"
Can anyone help?
Brett Sayles best get round my joint before I eat all his Furniture.
http://www.megamanual.com/connect.htm
any help mate?
only other thing i can suggest is that i come round with my mini laptop with serial ports that way we will know if its your microsquirt or usb - serial
Mate, i dont think my ecu has any firmware installed!!!
YAYYYY
Think ive sussed it, No firmware installed what so ever. Dick heads at trigger wheels failed.
Ill send them a shit sarnie
jbelanger
Member #: 831
Montreal, Canada
I think that they all come without any firmware installed so unless Trigger wheels specifically say otherwise, that's nothing unusual.
And you definitely should use the MS2/Extra code: http://www.msextra.com/downloads/
Jean
http://www.jbperf.com/
Ok im still having issues. I managed to upload the firmware and get the thing working, but then it started dropping connection.
So im trying to re upload it and getting error 0x0?
Any ideas
Turned out to be a babbad serial port.
damn serial ports!
They are utter plop mate
