| Home > Help Needed / General Tech Chat > Engine questions | |||||||
2nd Jun, 2015 at 07:24:47pm
Evening lads got a few questions to ask
2nd Jun, 2015 at 07:27:43pm
1. Do a dummy build an measure
2nd Jun, 2015 at 07:45:17pm
Dont ruin a good 295 head, just use a 940 |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
2nd Jun, 2015 at 09:01:44pm
I'd echo the above comments, the only way to find out how your deck height is to measure it, though make sure you do your compression ratio calcs before you do it so you know you can get enough out of the head to compensate.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
2nd Jun, 2015 at 09:16:15pm
Didnt wanna go down the 940 route sold all my 940's off now. i also believe my 295 isn't standard anyways
2nd Jun, 2015 at 10:21:23pm
Phil did me a 295 and a 940 and the 940 has produced more power, plus you can run 11 studs I run a supercharger and I don't care the TB is on the wrong side.
3rd Jun, 2015 at 07:11:38am
Thing that worry be using the 940 is the rings getting hot as the pocket is right in that area
3rd Jun, 2015 at 10:13:00am
Piston rings? Or fire rings? I run a supercharger and I don't care the TB is on the wrong side.
3rd Jun, 2015 at 10:26:34am
I would stick with the 295 as you already have it, it also has 28cc chambers for what you need. You will need to do a lot of work on a 940 to get the CR down. Plus I agree with the concern of valve pockets etc.
3rd Jun, 2015 at 10:33:13am
What about the avonbar phase 2 cam? My build thread..
3rd Jun, 2015 at 07:42:17pm
Where do you get that cam Paul?
On 3rd Jun, 2015 Paul S said:
I would stick with the 295 as you already have it, it also has 28cc chambers for what you need. You will need to do a lot of work on a 940 to get the CR down. Plus I agree with the concern of valve pockets etc. I don't think that you need to go as far as 29mm exhausts, 27mm will do. MD274 all the way. |
3rd Jun, 2015 at 07:48:26pm
Kent 😀 I run a supercharger and I don't care the TB is on the wrong side.
3rd Jun, 2015 at 07:55:33pm
Oh yeah the MD part throw me |
3rd Jun, 2015 at 08:04:34pm
Minispares list it as a MDM274 Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Jun, 2015 at 09:10:57pm
Sweet I'll order one of em then |
