Home > Help Needed / General Tech Chat > wheel ET offset help
D4VE
Member #: 10749
lowestoft suffolk
Hi right from what i gather ET is the measurement in mm? From the centre of the width of the rim to the mounting face?
So i take it if a wheel is 6 inch wide and has et 7 thats gonna be 3inch 7mm from hub? Am i right?
Now im looking at certain wheels and would like them to fit under standard mini plastic arches or group 2's
5x10 et 0 which i think will only just protrude the actual metal arch? Correct me if im wrong..
6x10 et 7 which i think will definitely not fit under plastic arch
6x10 et 6 which ive seen fit just under plastic arch BUT surely 1mm difference cant be the difference between under n way out?!?
Please explain this to dummy me?! The last thing i wanna do is buy wheels with a look im after then have to get bigger arches *oh well*
Nothing gets past Dave lol
If the ET doesn't have a - sign in front of it assume it is a + offset,
D4VE
Member #: 10749
lowestoft suffolk
So its half the width - the ET from hub to edge of rim?
Dont think I've ever seen a negative number ? That would really sit into the vehicle
http://www.willtheyfit.com/
you've got it wrong stevie, its the other way around,
positive means more into the car, neg means it sticks out form car,
carl
carl
I've never seen a wheel with a negative ET number.
They are always positive numbers, eg 10 to 50.
A higher number will mean wheel sits further in towards the car.
A number of 0 will sit quite far out.
And correct, calling numbers negative threw me off.
Edited by stevieturbo on 6th Jun, 2015.
D4VE
Member #: 10749
lowestoft suffolk
Yeah so a 5 inch wide wheel at 0 means it sits 2.5 inches either side of hub...
Where a 6 inch wide wheel with a ET 7 means the centre is 7mm further outer from the centre of wheel?
Edited by D4VE on 6th Jun, 2015.
jonny f
Member #: 9894
Dorking
spot on
Edit: whoops, no its the opposite.
-7 would stick out
7 would be inward
Edited by jonny f on 7th Jun, 2015.
nope,
with et 7 it will be 7 mm inset, with -7 wit will be 7mm outset...
D4VE
Member #: 10749
lowestoft suffolk
Well i have 5x10 with et 32 and theres like no dish at all hub is basically the outside of the wheel...
So basically et is how much hub goes towards outer rim and - et is hub towards inner rim
riiiight,
5" = 127mm
127/2 = 63.5mm
ssooo, 63.5mm-32 = 31.5 on the outside of the wheel,
amd 63.5 +32= 95.5 on the inside of the wheel.
both from the hubface.
basically - sticks out + stick in
