| Home > Help Needed / General Tech Chat > oil pressure | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
15th Jun, 2015 at 05:24:19pm
Hi just took the mini out for a spin to check for this weekend at pod..
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
15th Jun, 2015 at 06:01:06pm
Probably the heat, hot oil thins out. As long as it doesn't drop any lower than say 25psi at idle you'll be okay. On 26th Jan, 2012 Tom Fenton said:
15th Jun, 2015 at 07:02:30pm
What oil you using? My build thread..
15th Jun, 2015 at 07:03:12pm
On 15th Jun, 2015 Carlzilla said:
Probably the heat, hot oil thins out. As long as it doesn't drop any lower than say 25psi at idle you'll be okay. as carls says he is spot on i have seen oil pressure 10 psi ish HOT and the engines great
Edited by BENROSS on 15th Jun, 2015.
15th Jun, 2015 at 08:21:57pm
Its only been this low since the oil got hot at snetterton...
15th Jun, 2015 at 09:09:21pm
30psi hot is fine. Mines the same. In the 13's at last!.. Just |
16th Jun, 2015 at 12:49:32am
I'd be happy with that |
16th Jun, 2015 at 06:53:01am
On the idle rpm note... i been told on non standard cams you want a 1100rpm minimum?? On 24th Oct, 2015 jonny f said:
16th Jun, 2015 at 07:36:26am
Go as low as it'll happily idle. In the 13's at last!.. Just |
its never been that low? ? ?
