| Home > Help Needed / General Tech Chat > Clutch noise. Video added | |||||||
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
29th Jun, 2015 at 04:44:20pm
I have just started my new turbo engine for the first time. Everything is new and untested. Ive got it idling at 1800rpm to break in the cam, but i am concerned there is a lot of noise coming from the clutch area. Its got an RTS clutch, straight cut drops. There is a constant clattering noise which totally vanishes if i dip the clutch. The revs dont drop when i do this so theres a good thing at least. It aint the same noise you can get if you have your idle speed set too low and the drops rattle, this is louder and its there all the time
Edited by dazibee on 1st Jul, 2015. |
29th Jun, 2015 at 05:02:50pm
Sounds like there's nowt wrong.
29th Jun, 2015 at 05:21:41pm
Ive not let the revs drop below 1500rpm yet, the noise is constant, not really the random rattling you get from drops? |
29th Jun, 2015 at 10:27:46pm
Does it go away when you your clutch in? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
29th Jun, 2015 at 10:55:49pm
Can you get a video clip uploaded? |
30th Jun, 2015 at 05:45:39am
Goes quiet if I press the clutchpedal. |
30th Jun, 2015 at 05:46:03am
. Edited by dazibee on 30th Jun, 2015. |
30th Jun, 2015 at 06:17:42am
If you press the clutch the drops will stop spinning
Edited by Brett on 30th Jun, 2015. Yes i moved to the darkside |
30th Jun, 2015 at 09:23:52am
As the gents say above its a classic, especially. If the oil is hot and its hot weather like now.
30th Jun, 2015 at 09:37:05am
Turn the idle up, 2500 to knock the cam in!
30th Jun, 2015 at 10:47:22am
I recall Simon (madmk1's) car sounded terrible when he tried one of those A&R Precision aluminium flywheels.
30th Jun, 2015 at 04:17:49pm
The flywheel is steel from MED. The noise is better described as the noise you get from an alternator with knackered bearings. I'm hoping it is the clutch release bearing. |
30th Jun, 2015 at 04:24:11pm
I think that's what Si's sounded like.
1st Jul, 2015 at 08:32:17am
Put a video up, however I think your panicking for nothing, sounds like typical rattly drops, mine were horrifically loud to the point they hurt your ears. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
144 Posts Member #: 10557 Advanced Member |
1st Jul, 2015 at 10:38:30am
....and on the flip side my MED floating drops are silent at idle....no rhyme or reason to these things sometime
Edited by smokestack-lightning. on 1st Jul, 2015. Double-Blind experiment, N:
1st Jul, 2015 at 07:52:31pm
Edited by dazibee on 4th Jul, 2015. |
1st Jul, 2015 at 09:22:20pm
sounds very tinny...a bitmore like a clutch component than the drops...you usually get a very solid sounding clacking from them......hard to tell just from a video though..... Double-Blind experiment, N:
3rd Jul, 2015 at 05:56:35am
Anybody else think something is wrong after listening to the video? Its my first experience of straight cut drops, some more thoughts on this would be a great help Edited by dazibee on 7th Jul, 2015. |
8th Jul, 2015 at 08:13:50pm
Guys now ive put the video up any chance a few more of you could listen and tell whether the noise is normal or not. Ive got to pull the engine back out if the noise is wrong. Cheers |
9th Jul, 2015 at 08:16:44am
Drops, sound just like mine did.
Edited by MikeRace on 9th Jul, 2015. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Jul, 2015 at 04:35:12pm
On 9th Jul, 2015 MikeRace said:
Drops, sound just like mine did. Mike, was there any problem with yours or did it turn out to be normal? Cheers |
9th Jul, 2015 at 04:46:39pm
Nope no problems whats so ever.
9th Jul, 2015 at 05:17:10pm
Almost. Only thing stopping me driving it is lack of mot and worried that the noise is something serious |
9th Jul, 2015 at 06:06:11pm
Doesn't sound serious to me mate.
My build thread..
