Home > Help Needed / General Tech Chat > carb spacer
coopdog
Member #: 9628
ive wired my boost gauge off this carb spacer but it doesnt give me any readings
im going to add another takeoff like the others i have
my questions is do i need to have the spacer fitted or can i just remove it?
PhilR
Member #: 10034
Birmingham
No reading at all ??? You need to work out why you're not seeing boost from take off in the spacer - I can't see any reason why that won't give you a reading, or for that matter, why placing the take-off 3cm away will make any difference.
At least on NA engines the spacer is preferred as the slightly longer inlet tract could give a bit more torque low down. Better to block it off the pipe or even replace with a thicker one. If you really feel the need to remove it, make sure the butterfly can open fully without catching on the manifold casting.
It is a bit odd that you get no reading.
But you'll need the spacer of the throttle cam will hit the inlet. Even with the spacer mine hit.
coopdog
Member #: 9628
yeah ive tried blowing through and it is quite difficult,
they way i had wired up was the from the carb spacer take off to the boost gauge with the vaccum side of the DV t'd into it :/
Edited by coopdog on 15th Jul, 2015.
metroturbo
Member #: 989
North Yorkshire
Just tee into one of the other take offs. You don't need a seperate take off for every single use.
