Home > Help Needed / General Tech Chat > Turbo Gaskets
seahuston
Member #: 10666
California, USA
Is anyone using gaskets between the manifold and turbo, and turbo and downpipes? I feel like I should be using one but I haven't seen any mention or pictures of them around here.
I don't think I'm super blind but I might be!
lost of people just stick a smear of exhaust paste in there,
also heard of a smear of silicon,
also easy to cut one from copper sheet.
jakejakejake1
Member #: 10010
Northants
You can run gaskets if you want, I'm not sure what most people on here use but on our turbo Formula Student car we don't bother as you can blow a gasket when there isn't one fitted.
As long as both surfaces are nice and clean and flat they should seal alright without gaskets.
evolotion
Member #: 83
Glasgow, Scotland
yip rover didnt use exhaust gaskets on turbo to manifold joints, so long as both joints are flat they seal fine. I use a smear of very high temp selant on mine as its likely not that flat :)
Denis O'Brien.
