| Home > Help Needed / General Tech Chat > Build Planning: Drop engine through top or attached to subframe | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
22nd Jul, 2015 at 04:26:29am
I'm getting good progress along with my engine and front subframe and once the body gets back from paint there shouldn't be much stopping me from putting all the fun bits back together.
![]() 539 Posts Member #: 6807 Post Whore York |
22nd Jul, 2015 at 07:17:26am
Drop it in from the top after fitting the subframe.
22nd Jul, 2015 at 08:02:39am
if the turbo is fitted, you'll want to drop it in. if the engine is bare, you could fit the engine to the frame and slip in in from below.
22nd Jul, 2015 at 08:59:36am
fitted my engine in frame then frame into body then head complete with manifolds on hit he key
22nd Jul, 2015 at 11:01:32pm
Sounds good gang. I'll plan check for oil pressure before installing.
