| Home > Help Needed / General Tech Chat > Block drain plug | |||||||
22nd Jul, 2015 at 04:42:02pm
Hi
My build thread..
22nd Jul, 2015 at 04:44:22pm
ask Nick; there is one on the block he got off me |
22nd Jul, 2015 at 07:42:24pm
1/4" bsp straight. |
22nd Jul, 2015 at 08:52:51pm
so if i get it drilled and tapped to that and get a 1/4"-8mm tail hose, it should all fit together? lol My build thread..
22nd Jul, 2015 at 09:02:00pm
or would it be beneficial to go a bit bigger? My build thread..
22nd Jul, 2015 at 09:35:17pm
stick to that original size its more than up to it.
22nd Jul, 2015 at 09:38:50pm
Thanks guys :) My build thread..
22nd Jul, 2015 at 10:38:08pm
On 22nd Jul, 2015 JT said:
so if i get it drilled and tapped to that and get a 1/4"-8mm tail hose, it should all fit together? lol Surface needs to be faced off too if you stick with 1/4" bspp. A tapered 1/4 npt may be easier. There's also a couple other npt threads used on oil system so wouldn't be too out of place. I have no idea why they didn't just pick either BSP or NPT ! |
23rd Jul, 2015 at 12:01:30am
Don't use a Black & Decker! Make sure you drill it straight and don't go too deep. A member on TM managed to drill right through into #4 bore Edited by Sprocket on 23rd Jul, 2015. On 26th Oct, 2004 TurboDave16v said:
23rd Jul, 2015 at 07:16:25am
I also found that it is best to have a right angle adapter to get the water hose away from the exhaust manifold |
23rd Jul, 2015 at 09:01:25am
Ok cheers guys. Think I might let the machine shop do it as I got to get them to do a few bits to the block anyway :) My build thread..
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
23rd Jul, 2015 at 09:11:08am
i just got this http://www.ebay.co.uk/itm/360632843339 |
