Home > Help Needed / General Tech Chat > Cutting out under boost.. Sometimes
coopdog
Member #: 9628
Hi guys
Got the car running an driving lovely, passed the mot aswell
The only problem I have ATM is that the car completely cuts out under boost, but not all the time, if I baby it into boost to will get pretty far up the rev range before it cuts out, but if I'm trying to go for it like pulling out of a junction it will get through 1st gear but stall in second, so I have to turn the ignition off and start it again with a backfire
It will also misses a little bit when accelerating under boost
It does it at different times, I've looked at the map and have smoothed it out as much as I could but that hasn't helped
I'm running nodiz,
The thoughts I have ATM is that it's maybe the pipe going to the map sensor? I'm using the blue silicon stuff of eBay, can it balloon?
And the other one is maybe the crank sensor is moving round,
Thanks
Callum
Fuel, carb, t-piece trick.
sim_ou_nao
Member #: 114
Porto/Portugal
try rise the fuel pressure...
Pedro Silva
PhilR
Member #: 10034
Birmingham
Got a picture of the support?
How much can you move it by hand?
What's changed since you last had it running properly?
coopdog
Member #: 9628
You think it's fuel related then?
Seems to be running rich most of the time on the afr.
But I will have a look and try it :)
It seems pretty good tbh haha
And also I haven't had it running properly yet as it's only just got on the road
PhilR
Member #: 10034
Birmingham
To be blunt Callum, trying to help you is frustrating.
When you post a problem on here, people will always try to help you, but the fact is, you don't know what the cause is (and neither do we), so you need to try ALL the suggestions with an open mind and answer ALL the questions clearly. If you don't, then people won't bother replying a second time.
Honestly, no offence intended - I hope you fix your car.
coopdog
Member #: 9628
I just replied saying I'm gonna try what you guys said, I don't know what else you want me to reply with?
Also I don't wanna sound like a cunt back, I love this forum and the feel of it, I just seem to annoying most people on here :L
Sorry haha
Edited by coopdog on 31st Jul, 2015.
Callum, a hunch here fit new spark plugs first! I know they may be new. . . But fit New ones again!!
Espcially if its a new build
Then any missfires under boost are usually a lean mixture, take the advice above callum.
tadge44
Member #: 2500
Buckinghamshire
And make sure they are an appropriate heat range !
coopdog
Member #: 9628
I've done the t piece trick and it has settled the afr gauge down and I can now see at higher Rpms it is leaning off,
So I'm going to book into a rr and get it all sorted out
tadge44
Member #: 2500
Buckinghamshire
It may not be leaning off just because the gauge says so. If the plugs are wilting then free oxygen gets through and shows as a lean mixture, because the sensor is an oxygen sensor, not a mixture sensor.
Did you check or change the plugs yet ?
