Home > Help Needed / General Tech Chat > Alternators (desperate)
jonny f
Member #: 9894
Dorking
What small denso alternators are you guys using and from what car/part No.?
Am a little desperate.
Got a small denso/brise one on it at the moment and it seems shagged.
Regulator had died so voltage kept climbing up with rpm and has killed my battery to. Changed the regulator (possibly the wrong one couldn't find correct number) and it's puts out to much still although regulated 15.6 is a bit to much. Beats 19 though *wink*.
15.6 could be ok, if the batterys flat it will ramp the volts up to charge it.
give the battery a good chage then tart it and check its still high,
http://www.ebay.co.uk/itm/KUBOTA-40A-BRAND...=item1ea236fdac
http://www.ebay.co.uk/itm/Denso-Light-Weig...=item1a03fab03c
http://www.ebay.co.uk/itm/1075-NIPPON-DENS...=item2334374c3b
evolotion
Member #: 83
Glasgow, Scotland
15.6 is ok with the ford fast charge(calcium) batterys but it will certainty boil up regular batterys if it sustains it.
Denis O'Brien.
jonny f
Member #: 9894
Dorking
Hmm interesting. I'll check the battery later and see what its kicking out.
Thanks for the links/replies.
Edited by jonny f on 11th Aug, 2015.
jonny f
Member #: 9894
Dorking
To update, battery was ok, regulator I put in was incorrect and after I got the right one from a local auto electrician it was all good at 14.5.
Also new battery's a li-ion one :).
excelent!
I have killed a couple of regs in the past, its worth having a spare or two hanging around being as they are cheap.
jonny f
Member #: 9894
Dorking
Very happy to sort it pre MITP.
Cheers for your help again.
