Home > Introduce Yourself > Looking for a mini with potential to turbo.
SamFoster
Member #: 11205
Hi all.
Sorry in advance as these questions have probably been asked time and time again.
I'm looking at getting my first mini and was wondering what the cheapest/ most reliable way of getting more power would be? This will be my daily drive so with that in mind, would I be best turbo charging the standard engine or swapping for something like vtec etc?
this is the mini I have seen. http://www.ebay.co.uk/itm/321849747000?_tr...K%3AMEBIDX%3AIT
I'm looking at getting something pre 75. If anyone could give me an idea on cost I'd really appreciate it. I have looked on many forums and have just found this one so hopefully someone could give me a rough idea.
Thanks in advance
Sam.
Who doesn't feel even a little bit happier when a classic mini drives past them.
D4VE
Member #: 10749
lowestoft suffolk
Looks alright.. cant see an engine size in the add??
Nothing gets past Dave lol
Callum
Member #: 10396
Stoke-on-Trent
That's not in its original shell, so it's either...
stolen and put on other plates
has been reshelled as the original was past economical repair
Or just a ringer for the tax exemptness
You might not be bothered about any of that but if your after original it's not for you
Will
Member #: 11091
hes looking to turbo or maybe vtec a mini?
pretty sure original doesnt matter
if i was you id start from a shell!!
scoop-face
Member #: 11122
Scottish Borders.
If you want a daily driver enjoy the mini as it is, buy a second engine and turbo that so it can be dropped in when finished. Expect to spend £2,000-£3,000 in parts (assuming you can do the assembly yourself?)
I personally think the vtec would be slightly less work to build and instal (slightly!) and give a more reliable daily drive. And probably cost as much.
Buy a car that has a solid body, check the sills and wheel arches for rust along with front and rear sub frames. You don't want to buy a rust bucket that will cost you another 2 grand weld up!! (Like I have...)
Good luck!
Chalkie
Member #: 9764
Northamptonshire.
Words reliable and cheap don't go together
Edited by Chalkie on 2nd Sep, 2015.
SamFoster
Member #: 11205
Thanks for all the replies lads. Yeah I'm really only going for a pre 75 because it would be tax exempt haha (not sure how much you guys pay for tax on your minis?)
Yeah my ability is limited to general servicing really lol :(.
If turbo charging the standard engine is about as much work and price as the vtec swap, I think I would go for the vtec, just because of the bulletproof engine and starting power of 150bhp (i'm sure this is more than enough for a tiny mini).
thanks for all your help everyone, hopefully I can find a nice shell that needs no welding to start this process.
If I could I would put my Mitsubishi colt CZT engine in a mini, as its a 1.5 turbo but I can imagine the work would just be ridiculous to do that :.
I would say that a mild turbo build would be much simpler than an engine swap.
If you're not after big numbers, then it can be done fairly cheap too.
Shauna
Member #: 10424
Swansea boyo!
You should probably look into the price of the subframes and extra bits for a vtec conversation if that's the way you want to go and can't make one yourself. Personally I'd go for a clubby front because it's so tight under a standard round nose!
http://www.allspeedengineering.com/index.p...-b16-b18-detail
SamFoster
Member #: 11205
I did consider that Shauna, but can you beat the round nose look?! I think an A series turbo may be the one to go for. Surely it must be less hassle than having to put in an engine from a completely different car? Things would be a lot simpler if I knew what I was doing lol.
D4VE
Member #: 10749
lowestoft suffolk
Have a good read round here mate... plenty people mildly turbo'd there mini whilst on the road
As said above.. get something and enjoy it whilst building another engine
Edited by D4VE on 2nd Sep, 2015.
Shauna
Member #: 10424
Swansea boyo!
It's just a warning, it's TIGHT and that's for someone who has already done other engine conversions. I have a turbo daily and the only thing I really miss is 5th gear for motorway driving but I don't spend enough time on there so it's no biggie for me really. Personally I'd just buy a MOTed mini and build an engine to drop in. At least that way your driving it and getting a feel for it while building something you can drop in with a few weeks work.
SamFoster
Member #: 11205
Yeah building an engine while driving around sounds like the best option I think. I still have so many more questions, what turbo to use, which engine to go for, what upgrades does the engine need to handle the turbo.
I must have spent the whole of this week going through this, TMF and another mini forum getting ideas and reading different threads. So much to learn! lol
Thanks for all your help so far folks.
D4VE
Member #: 10749
lowestoft suffolk
Either try get a complete turbo lump or get any bottom end n source a head, carb, turbo and manifolds...
Car wise itll be bulkhead box (depending on manifolds)
Fuel lines larger and return and fuel pump
