Home > Help Needed / General Tech Chat > Question for the weight loss boys
slater
Member #: 1291
Suffolk / Birmingham
Why do you not run cable clutches?
Just been thinking about this as i was reading about people extending their clutch arms to run an RTS.. I run the cable clutch on my metro still and it works a dream (twin turbo plate RTS). Surely it saves a fair bit of weight? Has anyone considered it on mini? Weighed the various bits?
D4VE
Member #: 10749
lowestoft suffolk
Interesting....
Nothing gets past Dave lol
I had been thinking about this, but not got past the thinking part at the min lol.
I would say it would likely be heavier than the plastic can master etc. There's a lot of metal in the brackets and the cable is surprisingly heavy for what it is.
My thoughts too.
Nic Riz was looking at this a few years back I think.
slater
Member #: 1291
The cable is quite heavy but theres just the one bracket on the clutch cover which can be slimmed down quite a bit and probably weighs about the same as the bracket on the hyrdo verto setup if not a bit lighter.. You can take some weight out of the fork on the end of the cable too.
no slave, no cylinder, no fluid, same bracket pretty much. Slightly longer arm if you compare with the hyrdo verto but if your enlarging it its similar.
Might not save alot but ive seen people on here spend silly money to get a few 100g off their cars so i think people are probably missing a trick.
Interesting thought,
I will say, when I ran metro's I had a few faliures of the plastic bit on the end of the cable that hooks onto the pedal.
There was also a kit at one time that was like a push rod setup, can't think who used to make it.
SH Engineering. It was for Pre-Verto though.
I see,
mini93
Member #: 2017
Warwick.
I had the SH engineering clutch kit, with my grey plate it was a very heavy clutch! and no good for general driving about really. My knee swelled up a little on the london to brighton run from it
David.
Alex
Member #: 1851
Woolavington, Zummerzet
I think I've got some cable Verto arms somewhere.
Somewhere...
(and MadMk1's seen the size of the somewhere...)
Few people would ever favour cable vs hydraulic on any engine platform, and I really doubt the weight saving if any would ever be worth it vs a good light hydraulic setup
