Home > Help Needed / General Tech Chat > RTS clutch donors
Tuctuc
Member #: 10894
Lancashire
You've convinced me to go RTS, my existing clutch had a light green blob - looking at the paint codes this means someone has uprated it in the past?
It looks like an AP model with solid ring around the rivets so going to get a new minispares cover and plate and use the existing spring in that.
As for pedal pressure, if it's too high has anyone lengthened the arm or altered the piston size / reservoir to ease the pressure?
