Home > Help Needed / General Tech Chat > Ford EDIS 90 deg plug leads.
jonny f
Member #: 9894
Dorking
Does anyone have a part number for some leads to use with megajolt/EDIS unit that turn 90deg at the spark plug rather than coming straight up.
Been looking to no avail. I want to avoid making my own leads if possible.
Thank you :).
Edited by jonny f on 25th Sep, 2015.
metroturbo
Member #: 989
North Yorkshire
I ended up chopping the spark plug ends off some fiesta leads, and crimping on 90 deg ends using a coax cable crimping tool. Worked well, and my leads are exactly the length I wanted without having to shell out for leads being made.
PhilR
Member #: 10034
Birmingham
Soldering and crimping should be easy and give you the most options, but also, look for motorcycle screw in plug caps. No need to crimp as they have what looks like a small wood screw that you just twist the cable onto. Note that some also have a 5K resistor built in, so avoid those if you already have resisted plugs.
Edited by PhilR on 25th Sep, 2015.
jonny f
Member #: 9894
Dorking
Trying to be lazy here and avoiding buying two sets of leads!
Am aware I can do all that you've mentioned. Thanks a lot anyway :). I think I'll be cutting some up by the sound of it.
