| Home > Help Needed / General Tech Chat > What am I missing... | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
26th Sep, 2015 at 06:09:49pm
Chaps, just a quick one… I took the spark plugs out of the cylinders earlier and stuck the car in gear. I expected to be able to roll the car back and forth and the engine would turn over as in gear. Nothing was happening, couldn't move car, it was like stuck in gear as normal with compression. Am I missing something obvious?
![]() 1751 Posts Member #: 10190 Post Whore belgium |
26th Sep, 2015 at 06:22:20pm
Is it a new build? Valve hitting piston or old engine valve stuck? you can do anything if you set your mind to it...
26th Sep, 2015 at 06:31:14pm
What gear? On 26th Oct, 2004 TurboDave16v said:
26th Sep, 2015 at 06:39:57pm
Yes a new engine built engine. Tried 1st gear, couldn't get it to stay in. Tried it last in reverse... |
26th Sep, 2015 at 06:47:04pm
Try 3rd or 4th
26th Sep, 2015 at 06:50:37pm
Ok cheers, I'll try that. |
26th Sep, 2015 at 06:54:40pm
If you're in first gear, for every turn of the road wheel, you're trying to turn the crank about 10 times; 4th gear is easier because you only turn the crank about 3 times |
26th Sep, 2015 at 06:59:12pm
Just been out there guys, yep.. managed it in both 3rd and 4th.
