| Home > Help Needed / General Tech Chat > turbo wastegate actuator problems | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
14th Oct, 2015 at 06:11:46pm
I recently bought a gt1544 received it through the post today and notice the wastegate flap is permanently open but isn't seized and can be pushed easily back using the actuator arm or if I suck on the pipe on the actuator it pulls it back into position
14th Oct, 2015 at 08:26:48pm
No doubt it's a vacuum operated setup from a diesel, so needs vacuum applied to the can in order to shut the valve to make boost. 9.85 @ 145mph
14th Oct, 2015 at 08:33:39pm
Oops ok thank you |
14th Oct, 2015 at 08:51:17pm
So does that mean I can use it on a 998 I just need to connect the actuator pipe to my inlet manifold |
14th Oct, 2015 at 08:55:29pm
It means you need an actuator that works on pressure. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Oct, 2015 at 09:06:23pm
Ah ok that's not a problem then thank you |
