Home > Help Needed / General Tech Chat > distibutor
ben doodar
Member #: 595
stoke on trent
hi was wondering if any1 knows what distiutar i can use with my metro turbo engine. its a standard engine with a intercooler and hopefully a two stage boost something quite standard say 4 psi to say10-12 i only want a standard 1 as ive bought a engine and it hasnt got a dizzy or a carb and manifold. also wot drive shafts would be suitable for this engine. and in standard form does the metro turbo have double valve springs as well as hes gave me these with the engine. would really apreciate your help d*smiley*dar
Nick
Member #: 154
Midlands
you'll need a metro turbo dizzy, they've got a different curve to the NA variety.
The standard turbo head did come with double springs yes.
As for driveshafts it depends on your diff really...i'd say that you'll probably be running pot joint type ones which are the most common and came on the metro/mini as standard although they are different lengths i believe between the 2 cars. the mini definately has the n/s one shorter than the o/s anyway.
Nick :)
ben doodar
Member #: 595
stoke on trent
o rite then cheers bud. im only going be running a fairly standard engine and im not the kinda person do a big stinky burn out and snap a drive shaft so will my mini 1s be o.k. is there anything unobvious il have to change or is there anything u wud recomend changing. thank you please
Your standard mini driveshafts will be fine, obviously make sure the CV joints are not on their last legs.
Other than that, have a read through the site.
There are too many things to list that you could change, it is up to how much money you want to spend and what you want to use the car for.
As is widely written, the gearbox in particular the drop gears and diff are weak points, so any money spent here is definately worthwhile.
ben doodar
Member #: 595
stoke on trent
my mini is mechanicle fine, its just know winter is setting in it will give me and a couple of mates something to do at night. ive just been round my mates garage on my dinner break and was looking at a old technical data book and it said the metro turbo used the same carb type and model as the n/a metro 1275 so would this carb be usable on the turbo plus wot is the difference between the sportex inlet ive got on my mini and the turbo one, my mate the mechanic said id have to use a turbo one. but i was wondering the differnce.
ben doodar
Member #: 595
stoke on trent
also it said the metro turbo was 93 bhp and the mini era turbo was 95 i think. wots the differnce between the two. as i think mine is a era 1 il check the engine numbers 2morrow morning when i wake up with a great big hang over from my mates wedding reception tonite
Metro turbo engines have a "book" power of 94bhp, that goes for the ERA Turbos as well. Its only a guide figure really, don't take it as gospel.
Metro turbo carburettor although similar to the n/a metro carb is not the same. It has improved sealing and also is boost sensitive. It is possible to convert a NA carb to work with the turbo, but it is a lot easier if you can get hold of the right carb to start with. Keep your eye on ebay they seem to pop up regularly.
ben doodar
Member #: 595
stoke on trent
so wot about my inlet manifold wot i bought to use with a l,c,b exhaust. would i be able to use the sportex inlet with a turbo carb i cant think of any differnce can u?
The turbo inlet is a different shape to stop mixture leaning out on the inner two cylinders when on boost.
You need the proper manifold really.
All of this has been covered many times in the forum, I suggest you need to do a search and some reading up of past topics to gain some knowledge you will find useful. :)
Nick
Member #: 154
Midlands
also with a NA inlet you wont have a chance of getting underneath to tighten up the manifold nuts. Much easier to get hold of a Turbo carb and inlet off ebay if you spot one.
plus i found with my howley manifokd that the plenum chamber wouldnt fit in, its ok with the std mg mutro though
