| Home > Help Needed / General Tech Chat > Bearing for the 1st motion shaft. | |||||||
3rd Sep, 2005 at 02:35:33pm
Hi, Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
3rd Sep, 2005 at 02:47:22pm
I personally run the standard sized bearing with a standard sized transfer case. However that is with SC drops
3rd Sep, 2005 at 07:31:05pm
the standard nose is ok on either gear set.
4th Sep, 2005 at 03:13:28pm
I got the turbo type bearing from a bearing supply company for ?11 if I remember rightly.
4th Sep, 2005 at 06:14:29pm
Thanks Guys.. Minits it is then. :) Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
9th Sep, 2005 at 02:00:50pm
Ok i've gone for the STD bearing with the plastic cage. Which way around should it be installed ?
9th Sep, 2005 at 02:41:58pm
i can check mine when i get back from work if no-one else has found out by then. On 20th Oct, 2015 Tom Fenton said:
68 Posts Member #: 596 Advanced Member |
28th Sep, 2005 at 09:18:08pm
Part number for turbo first motion bearing is 2/LRJ15.8, Rover list them as ADU6003. Minispares want £50+VAT. I bought one from a local bearing place today for £24+VAT!
