Home > Help Needed / General Tech Chat > Checking Cam wear
ian2000t
Member #: 2764
Halesowen
Just building up my turbo engine at the moment, and I want, if possible, to use my Morspeed Phase 2 cam. It's a very tractable torquey cam, which has always returned good MPG.
How can I tell if it is still usable, or if it has worn excessively? Is it just a case of measuring the difference between minimum/maximum lift, and checking it matches the figures here:
The Morspeed phase 2 (Fast road) Based on 1 example only;
Checking height: 0.016" @ lobe
Timing: (Intake): 20/52 (Exhaust): 56/16
Nominal lobe lift: (Intake): 0.305" (Exhaust): 0.298"
Duration (Intake): 252 (Exhaust): 252
Lobe centre angle (Intake): 106 (Exhaust): 110
Lobe separation angle: 108
Lift on overlap: 0.048"
Accuracy: Good
I can post a pic if it helps. I know the Morspeed cams are a bit hit and miss, some wearing quite quickly, so thought I'd better check it.
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
slater
Member #: 1291
Suffolk / Birmingham
And a good visual inspection. Usually you will get some pitting on the cam if it's had a hard life.
also check the max lift for each lobe with a dti with it in the block, if any of the lobes are drasically different then its on its way out.
ian2000t
Member #: 2764
Halesowen
OK, can't check it in the block at the moment as its at my mates garage.
Also found my digital callipers gave a flat battery, and my mechanical ones are too small!
So, here's a couple of pics, there does seem to be some strange wear patterns on it.
Could you have a look, and give me your thoughts based on the pics?
https://goo.gl/photos/5aQK8gfMJKZk7GYy5
https://goo.gl/photos/VnoByuFPRabzLRyw6
https://goo.gl/photos/bYeNKtcC1DEpYGMu7
Looks to be a lot of life left in it yet.
PhilR
Member #: 10034
Birmingham
The patterns look fine - that's just how the original coating wears off.
Check for pitting on or close the lobe tips.
ian2000t
Member #: 2764
Halesowen
OK thanks guys, can't see any pitting near the lobe tips!
