| Home > Help Needed / General Tech Chat > Lightweight batteries and chargers | |||||||
65 Posts Member #: 8079 Advanced Member York |
13th Dec, 2015 at 05:29:05pm
Hi all,
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
13th Dec, 2015 at 05:47:20pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=577110 On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
13th Dec, 2015 at 06:22:32pm
Copied from Audrey_Boy's build thread.
On 19th Aug, 2015 Aubrey_Boy said:
So after the usual unhealthy amount of testing and dithering;
My choice of lightweight battery which IMO can best cope with likely maximum in car charge rates and being sat outside in the overnight frost but still able to start
It's not the lightest but was the best compromise whilst sticking to the self imposed rule of saving as much weight as possible but without any loss of function I really like the terminal posts, some of the other batteries I tried felt like the terminal was going part company with the battery body before you had tightened it sufficiently. Cheers |
13th Dec, 2015 at 07:12:15pm
14th Dec, 2015 at 12:42:23am
nah i use a magneti marelli YTX14-BS |
14th Dec, 2015 at 07:39:53am
This is what I've been using - Minus the charger. I've been using a regular charger when it's needed it. Well happy with it. It has more grunt than the huge standard battery and got me all the way from Harlow to Princess Risborough without a working alternator.
In the 13's at last!.. Just |
14th Dec, 2015 at 12:02:40pm
On 14th Dec, 2015 theoneeyedlizard said:
This is what I've been using - Minus the charger. I've been using a regular charger when it's needed it. Well happy with it. It has more grunt than the huge standard battery and got me all the way from Harlow to Princess Risborough without a working alternator. http://www.ebay.co.uk/ulk/itm/161223617340 I had one them as well. Good little battery for the money. I only change it because my alternator reg went and overcharged the battery. |
14th Dec, 2015 at 04:54:37pm
I've just ordered one of those that Gary linked, perfect for what I want, couldn't decide on a battery so got the battery/tray bundle. Thanks! On 26th Jan, 2012 Tom Fenton said:
14th Dec, 2015 at 06:24:09pm
Thats a bargain!!!! They a simple swap over? Dont want to overcharge it/blow it up etc if its ok im goin for it! Did i miss a weight? On 24th Oct, 2015 jonny f said:
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
14th Dec, 2015 at 06:33:46pm
It says 6.5kg in the specification
On 14th Dec, 2015 D4VE said:
Thats a bargain!!!! They a simple swap over? Dont want to overcharge it/blow it up etc if its ok im goin for it! Did i miss a weight? |
14th Dec, 2015 at 06:40:28pm
Ah yes i see that now haha.. im very tempted! Just scared of 'what ifs' On 24th Oct, 2015 jonny f said:
14th Dec, 2015 at 08:03:23pm
I've ordered one too - they'll be wondering what's happening! Edited by graemec on 14th Dec, 2015. |
14th Dec, 2015 at 08:08:32pm
My friend says it will start and run the mini fine but it will get charged too quickly therefore killing it quickly On 24th Oct, 2015 jonny f said:
14th Dec, 2015 at 08:11:04pm
Only one way to find out! On 7th Oct, 2010 5haneJ said:
14th Dec, 2015 at 08:31:44pm
powervamp isn't lithium.
14th Dec, 2015 at 11:38:39pm
Jonny what about that model battery made you choose that one as theres tonnes of different ones from them On 24th Oct, 2015 jonny f said:
15th Dec, 2015 at 12:05:17am
YTX14-BS was talked about somewhere starting a mini fine. Its a general battery code so i just went for it and bought a good named one. |
15th Dec, 2015 at 02:03:00pm
The powervamp I ordered turned up today, how's that for service! On 26th Jan, 2012 Tom Fenton said:
15th Dec, 2015 at 05:54:35pm
17th Dec, 2015 at 10:28:27pm
So, can you just put a lithium battery in place of a lead one and they can cope ok with the alternator charge ok? Saying that, I am tempted by that powervamp one as its probably already a fair saving over the one I have in. What's a standard mini battery weigh in comparison? |
17th Dec, 2015 at 11:18:19pm
Normal ones about 11kg... i nicked a smaller thinner one out of another mini of mine for the turbo but weirdly weighed more?!?!?! On 24th Oct, 2015 jonny f said:
