Home > Technical Chat > difference between T3 and T25
martpaul
Member #: 668
newton aycliffe (near durham)
I was wondering if you could help, Whats the difference between a T3 and T25 power ect?
Does the T25 need bulkhead mods?
Is the T25 any better for the engine life?
Is there anything i should know bout the T25?
Cheers Martin
the t2 is only slightly larger than the t2, if you search for t2 t3 you'll fine lots of info, this had allready been convered.
jonnyturbo
Member #: 676
the t25 is normally found on a Rover 220 turbo. It's slightly smaller than the t3 so will spinn up faster.
