Home > Help Needed / General Tech Chat > ap caliper vs alloy caliper
D4VE
Member #: 10749
lowestoft suffolk
Weightwise does anyone know the difference between the 10" cooper s ap caliper and say the minispares alloy 10 "caliper (i take it there still the best/dust seal etc? )
Nothing gets past Dave lol
Nick
Member #: 154
Midlands
I can weigh an S calliper later if needs be
D4VE
Member #: 10749
lowestoft suffolk
Much appreciated, no rush.. is that what you'll be running?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
when i get back from the parents place i can weigh one of my mini sport 8.4" alu 4 pot calipers they are the vented type tho also they will have the brake line still attached as id want to kept the system bead lol probaly not the type ur wanting a weight on..
D4VE
Member #: 10749
lowestoft suffolk
Itll help guage the difference, thanks
Nick
Member #: 154
Midlands
2.97kg for a Minispares knock off S calliper with pads and pins.
I'm sticking with them for now, leaving all the easy bolt on bits to swap for lighter stuff in the future.
kezzboycat
Member #: 10371
leicestershire
i maybe able to weight my minisport 7.9 calliper tomorrow if you wish
D4VE
Member #: 10749
lowestoft suffolk
Cheers nick! *smiley*
Kezzboy cat... thatll be much apprecitated! No rush tho, especially with it bein chrimbo n everything *smiley*
JT
Member #: 637
Hertfordshire
I'd be able to weigh a kad 7.9" vented caliper with pins and pads if you like?
My build thread..
D4VE
Member #: 10749
lowestoft suffolk
Yeah please *smiley*
I put some decent weights on my build thread for 7.9s and my new settup if you dont mind scrolling back a couple pages
Disc..................5.465kg!!!!!!
Flange...............1.285kg
Bolts x4 ............82g
Hub...................2.865kg built
Caliper...............2.045kg
Mounts..............500g each
Mount bolts........100.8g
12.342kg per built hub..*surprised**surprised*
7.9 caliper....1.670
7.9 disc vent disc inc flange...4.615
7.9 vent disc..3.330
Weight of 7.9 inch settup...9.150kg
8.4inch disc...2.880kg
